southern MN | I have no actual clue.
I believe the app uses Bluetooth? Sometimes an app will constantly search for its Bluetooth partner, draining the battery trying to find the other half.
Would turning Bluetooth off, or can you shut that 'searching' down in the app, help?
I'm just grasping at straws....
Edit - it appears the app always looks for the drone - which isn't a bad thing if they lose each other you want that...... You need to close the drone app shut it down, not just go away from it, but actually close it.
http://www.phantompilots.com/threads/dji-pilot-draining-phone-batte...
Paul
Edited by paul the original 12/14/2015 16:41
