Search Forums | Classifieds (212) | Skins | Language
What use to kill road ditch??
ark plow boy
Posted 7/15/2008 20:54 (#415988)
Subject: What use to kill road ditch??
Mc Crory, AR.
What to You use around the farm to kill the grasses in the road ditches? There is a chemical called Habitat that sup post to work good, but it is very expensive about $60/acre. Round-up will not kill because it will not go past the water line if the grass is in the water. I have been cleaning out the spray rig with Clorox, and running it through the booms. Where ever I sprayed it  kills everything. I wonder if it would work to clean the ditches. It sure would be cheap. Any other ideas?
