Search Forums | Classifieds (139) | Skins | Language
cruizer - antenna offset?
gene_champ
Posted 5/11/2008 09:58 (#375607)
Subject: cruizer - antenna offset?
NC Iowa
i got the cruizer mainly for spraying. to get used to it, i have it in the tractor pulling the field cult, so i can see how close it actually is.
it is right on going one way, but coming back, it is wanting me to overlap about 2 feet.
i have the patch antenna in the center of cab roof. i messed with the offset setting in the control panel, and got it much better. i sure wasn't expecting to have to do that tho. is this the correct way to set it up, or do i have some other issue? this will work, but dosn't seem like the right way to have to do it.
i want to get this set right, as 2 feet is more overlap than i want for spray.
