| Well I'm as new to E-Z Steer as you can get and while the steering is easy the input and recording of what operation I'm performing is anything but easy. I input a number of my fields onto the 500 by using a jump drive. Went out and did a pre plant spray operation on the fields and everything went well. When I went back to a field to do the seeding the 500 let me change implement size, overlap... but would not alow me to change the event. I tried all sorts of ways to get what I thought I wanted it to do but no luck. At one point it told me that I had to make a new field. That just does not seem right can anyone help me or am I past the point of help. | |
