Search Forums | Classifieds (96) | Skins | Language
Insight/rawson?
agboy
Posted 5/6/2008 18:40 (#372568)
Subject: Insight/rawson?
Flandreau, SD
I have two Insights serial controling Rawson drives, one for seed and one for dry fert.
Both of them seem to lock up on the rate.  The target rates change and match the Rx or just flat rate.  the Rawson changes with the target rate and the planter monitor confirms the seed rate changes.
But the rate on the right of screen is locked solid on one rate.  Color of map is one color for that rate.
I have only looked at one field in SMS that this has happen and it seemed to log the changed rates correctly.
And sidenote, there is a fix for the backwards arrow/autoswath deal.  I have not put it in yet to try. contact your dealer.
