Search Forums | Classifieds (46) | Skins | Language
EZ-Steer steering offline w/ EZ-Boom
AFSWannabe
Posted 5/5/2008 22:30 (#372105)
Subject: EZ-Steer steering offline w/ EZ-Boom
We have an EZ-Boom installed with an EZ-Steer 500 system. Everything was working fine until customer moved system from planting tractor to sprayer this morning. When he is spraying, he is about six feet off of the foam marker (too close) and the outside boom section shuts off. The display is showing that the machine is running on the guidance line correctly - but in reality it is about six feet too close. It seems that the EZ-Boom knows where it is, but the EZ-Steer is off. We have checked the implement settings as well as the vehicle set up, and everything seems to be in order. This didn't happen until the system was moved this morning. We had the sprayer calibrated quite nicely a week ago and saved the configuration for him. Where do we go from here? Cables, Tilt Calibration, ?????
Thanks.
