Search Forums | Classifieds (109) | Skins | Language
EZ Steer/EZ Guide 500 having "S" Pattern Problems
isuman
Posted 5/5/2008 19:06 (#371977)
Subject: EZ Steer/EZ Guide 500 having "S" Pattern Problems
Central Iowa
Just installed EZ Guide 500 and EZ Steer on my Case 9350 and it is making an "S" pattern in the field. I have tried everything that I can think of to fix it including talking to Ag Leader tech support. Changed Online aggressivness from 85% all the way to 135% in 5% increments. Changed Angle per turn from 15% to 20%, changed the free play from 0" to 4" in increments of 1" and that didn't fix anything. It will run along at 0"-8" offline for a couple hundered feet and then all of the sudden it will change to 1'-3' offline back and forth. It seems to do it more so on hill sides and crossing waterways than on the flat. Have recalibrated T2 controller and it came up with a .8L and still the same problem. T2 controller is on the floor backwards facing, EZ Steer is mounted at 3 o clock on the steering wheel. Also messed with antenna to axle position from 12" behind, 0", 12" in front. Changed wheel base from 118" to 59" per request of tech support.
Anyways, thanks for any advice you may have.
