Search Forums | Classifieds (46) | Skins | Language
EZ-Boom/ EZ-Guide Plus operation
560man
Posted 5/4/2008 23:03 (#371569)
Subject: EZ-Boom/ EZ-Guide Plus operation
Northeast ND
I am thinking about getting an EZ-Boom system to go with my EZ-Guide Plus lightbar. Anybody run this setup? I have a question:
I use "adaptive curve" most of the time when I'm spraying. If I turn the lightbar on, go around the edges of the field to make headlands, and then set my A point and start going back and forth, will the EZ-boom shut off the boom sections whenever I get to the headlands that I made earlier, even though I wasn't using guidance at that time?
Now, let's say that it is a field where at some point I need to start on another edge, therefore resetting the guidance, new A point, etc. Will the EZ-boom know that the headlands were already sprayed?
Just wondering if an EZ-boom will work the way I want it to on our oddest-shaped fields -- the fields where it could pay for itself quickest, if it works!
Thanks
