![](/profile/get-photo.asp?memberid=326&type=profile&rnd=727) Bardstown,KY | I have a cultiva ATC controller that I want to send GPS from to my PFadvantage and my rinex controller with a Y-cable. I have a cable that came with my rinex that I think is a null modem cable because the 2 and 3 wires are crossed, I hooked one end of this cable to the ATC and the other to the rinex and it wouldn't work. I set the baud rate on the rinex from 19200 down to 9600 and it shows GPS signal now. I hooked the same cable to my PFadvantage and can't get it to show signal. The PF uses a adaptor cable off of AUX port 1 that I am hooking my cable to from the ATC. What could be causing my PF not to recognize the signal . Thanks for any help ,Todd | |
