Search Forums | Classifieds (102) | Skins | Language
how to adjsut throttle speed on 4450 JD??
jdmech
Posted 7/27/2006 23:26 (#30483 - in reply to #30188)
Subject: Re: how to adjsut throttle speed on 4450 JD??
there is a turnbuckle in the linkage. it is located behind the right hand side panel just ahead of the cab. loosen the jam nuts and turn to desired position. there is also stop bolts on the throttle handle itself. they are behind that plastic plug on the console by the lever (about two inches round). you can adjust those so the lever doesnt move as far either way (slow or fast).
