Search Forums | Classifieds (119) | Skins | Language
microbicide for B11 diesel
JohnW
Posted 7/25/2006 02:07 (#29623 - in reply to #29562)
Subject: Re: microbicide for B11 diesel
NW Washington
I think you can use the same biocide as you use in straight diesel. Not sure about a dispersant, as I believe biodiesel tends to pick up water without any help. Filter normal filter should be fine, unless your suspicious of the fuel quality. Sometimes you may get some initial filter plugging because the biodiesel is a good solvent and may cause some crud in the system to suddenly disolve and head for the filter. When using B11 this should not be much of an issue.
Check the Biodiesel page. It has a lot of info and should answer your questions or tell you where to ask. http://biodiesel.org/
