Search Forums | Classifieds (133) | Skins | Language
CCS planter plumbing with 9 pictures
simscott
Posted 3/16/2008 21:26 (#335460)
Subject: CCS planter plumbing with 9 pictures
Dalhart Texas
We recently finished plumbing fertilizer and herbicide on our planter. I thought it turned out nice. We had to make spray booms from scratch since Deere doesnt offer them on a CCS planter.
The nozzle pitch is adjustable via a set screw. They lean back slightly in the picture below.
Below is the herbicide flow meter mounted behind the vaccuum gauge and psi gauges for the herb & fert.
The top Redball is fert, the bottom is herbicide. they are mounted 3 rows in from the outside of the wings.
This is the fertilizer metering unit.
3 valves from trailer mounted on bottom step of planter.
Tank plumbing on planter tank so we can run fert or herbicide thru it.
And the trailer fill ports.
Also the monitor mounts in the 8430. Note that the raven harness is all stuffed behind the right hand console so that you dont have to look at it.
