Search Forums | Classifieds (23) | Skins | Language
gyro position
Lostfarmers
Posted 7/12/2006 20:27 (#25953)
Subject: gyro position
I have seen the talk about the antenna position on a cat tractor but does the gyro steering position sensor location matter as well. I am using an experimental raven smartrax on a 35 challenger and have trouble with the line acquire and sometimes wondering on line. the system uses a gyro for steering position but I also have the steering enhancer with the 410 receiver. I am curious if the location of the two gyros (about 3 ft one in front of the other) and the position of the antenna (on top of cab towards front) are causing some sort of interference. the system works very well as long as it comes on line quickly, if it comes to the row off line it wants to over correct for about 100 ft before it finally comes on line.
