Posted 7/8/2006 02:04 (#24777 - in reply to #24692) Subject: Re: Ideas to help a 2388 chop straw - Another try at attaching a photo
NW Washington
If you have a chopper replacing the fixed knives with sickle sections helps. You can by a kit change over, but you do the retro-fit yourself if your handy. http://harvesting.com/combine/case-ih/index.htm The link is hopefully to the CIH Combine Talk attachment page, but I am not sure where it will take you.
For a high priced fix you can switch to a Redekop MAV chopper that grinds up both chaff and straw. http://redekopmfg.com/
