Brazilton KS | Napa or any other good parts store should have them on the shelf, as well as Wal-Mart's automotive department. It's the same bulb most all cheap aftermarket driving lights and fog lights use. Also used in the cab lights on a Magnum and if I remember right in some of the lights on a little Challenger (which would mean in a Genesis also) They exist in 100w and 150w too, but think about what is around the bulb before you decide more watts are better.....the 55w gets hot and the 100 and 150 get a lot hotter.
About $3.50 at Wallyworld or JC Witney. Probably $9 at the dealers.
The bulb you are looking for is called an H3 and the one you have is 55 watt. | |
