Search Forums | Classifieds (84) | Skins | Language
Other uses for wheat/oats straw
JohnW
Posted 7/5/2006 01:45 (#24158 - in reply to #24081)
Subject: Re: Other uses for wheat/oats straw
NW Washington
I think you are referring to a material called "strawboard" which can be made out of just about any kind of straw, like wheat, oats, barley or even grass in grass-seed production. I am not sure that the economics of the process can compete with wood based particle board and waferboard (osb) at the present time. Here is some info on "strawboard".
http://www.fiberfutures.org/straw/main_pages/07_markets/files/straw...
Straw is also used to make erosion mats for use on construction sites to reduce erosion and help establish a ground cover. I would guess that this would be a good way to spread weeds, but maybe not.
I recently heard a USDA guy talk about research on a "gasification" process that would take biomass like straw and grass and convert it directly into alcohol and by-pass the regular fermention process normally used. I believe they are supposed to have an experimental pilot plant operating in Washington state this year.
