| My 8100 has a brake issue. when you switch on the mfwd to the position where pushing the brakes turns it off, the mfwd doesn't come on. I can pull up the pedals with my foot a little and the light/mfwd comes on and engages. Also seems the right pedal is real hard when pushing now. If I push it 3 or 4 times it returns to normal hardness for a bit. I can also push the left pedal a couple of times and it will then come up for a bit. Eventually it lowers slightly(just enough for light to not go on). I don't do row crop, but the switch is handy for turning at end of hay rows in hills with baler. About 4700hrs on tractor. Any ideas about common problem here with the tractor?
Thanks
Art | |
