Posted 11/12/2007 13:13 (#236460) Subject: tru count clutches GPS?
Flandreau, SD
IF you use the clutches what antenna is good. Is the Waas antenna work ok.
From what I seen useing th EZ + on my Insight for yeild maps, It would not be accurate enough to shut down rows for takeing 4 or 5 rows on a 6 row head. So I am assumeing that to use these clutches right, you would need to be at least on XP subscription?
