Search Forums | Classifieds (34) | Skins | Language
easy way to turn EZ 500 coverage map on &off?
kb ag
Posted 8/13/2007 00:29 (#186527)
Subject: easy way to turn EZ 500 coverage map on &off?
nc ks
Is there a easy way to turn the coverage map on and off when using a grain drill? In my sprayer the EZ boom turns the coverage map on and off. I will have a John Deere 250 planter monitor monitoring the seed, is there a way to turn on the map when it is 'energized and counting seed'? If not, what's the best switch to put on the drill and where do you hook it in to the 500. It will have EZ steer with T2 hooked to it part of the time.
