Search Forums | Classifieds (69) | Skins | Language
Case 1200 Planter with AFS Universal Display Plus...Can I tap into the Implement switch?
DG N. AL
Posted 5/4/2006 12:28 (#9943 - in reply to #9924)
Subject: RE: Case 1200 Planter with AFS Universal Display Plus...Can I tap into the Implement switch?
Hillsboro, AL
The AFS display is nothing but a dumb terminal.  The actual computer is the box on the planter.  So, the implement switch as such does not run to the display.  Think of the display like the monitor on your desk.  While it is possible to use the implement switch with the Ipaq, you will have to be carefully doing it.  You can not run 12v into the Ipaq.  You can use an IFB or a relay setup, but you will have to know what you are doing to accomplish it.
