Search Forums | Classifieds (151) | Skins | Language
Implement switch for Insight with muilt product unlock
CropperGPS
Posted 4/29/2006 11:57 (#8646)
Subject: Implement switch for Insight with muilt product unlock
I'm trying to use the multi product unlock on the Insight to record hybrids (area applied) and record starter fertilizer (record rate). I have successfully set up the configuration not using an implement switch but as soon as I try to use an implement switch an error message states that this configuration is not compatible with the attached module. Any thoughts???
Mark
