| A+ lets you specify a heading. For example, you can set your A point, input 147 degrees, and it will snap a line at 147 degrees from your A point. No B point required. Also lets you continue on your previous heading if, for example, you have to cross a road or waterway and need to continue with passes on the other side at the same heading.
Can't remember the keystrokes for saving/restoring AB lines right now. Someone else probably can. It's in the documentation on the EZ-Steer site, I'm pretty sure. | |
