ecmn | If you can follow the linkage to the right side, can you roll the cam a little more and see if it locks, otherwise you probably need to roll transmissions out the back, on the gear box the shift cover on the right side can come off and service park.
If linkage is good, roller or came could be damaged
About the 7 minute mark you can see the park pawl and roller
https://youtu.be/rskjyFIv2UI?si=w7GozJS8TzKbNL4V
Edited by easymoney 3/13/2025 13:35
