Search Forums | Classifieds (53) | Skins | Language
Hesston 4750 pickup help
matt suco
Posted 3/13/2025 12:42 (#11145267 - in reply to #11145129)
Subject: RE: Hesston 4750 pickup help
Rome, KS
I replaced that a year ago. I ended up putting a jack under the pickup and raising it as far as I could. Don't remember what I had to unhook on the side to get it to go up farther. But that should give you enough room to wiggle it out. If you are replacing that piece, look at all the sheet metal behind it and the sheet metal on the back of the pickup. They may be thin also. Maize Corporation in Maize KS has weld in liners for the pickup. Also look at the flighting in the pickup. They have that also.
