Search Forums | Classifieds (253) | Skins | Language
Kinze 3700 liquid tank
NEILFarmer
Posted 3/13/2025 13:56 (#11145348 - in reply to #11145069)
Subject: RE: Kinze 3700 liquid tank
Morris, IL
No first hand experience but I have same planter and I’ve been thinking of doing the same. One idea for me is remove the markers, saves some weight too. I have also thought of mounting a tank like this in that area they have 250-4-500 gallon ones. I actually have few on my spray trailer work good little easier to make brackets everything is flat. The disadvantage is not a total drain but if you put a bottom outlet they work pretty good.
What are you thinking of doing for pump? I see in manual Kinze made a piston pump bracket that mounted on planter frame and when unfolded it made contact with big main frame flotation tires, I would like to round up one of them myself.
https://www.dultmeier.com/narrow-slimline-utility-tank-500-gallons-7...
