Search Forums | Classifieds (250) | Skins | Language
Which relay, switch, connectors, etc to connect pull-type sprayer to tractor power
MiradaAcres
Posted 3/13/2025 07:31 (#11144843 - in reply to #11144798)
Subject: RE: Which relay, switch, connectors, etc to connect pull-type sprayer to tractor power
scmn
Pretty common on Deutsch to splice (2) 14ga to a 10ga wire and pin 14ga thru HDP series to pass more than 13A per pin. When doing this it helps to separate pins and run 1-2A cicuits between to keep the connector cool. Some HDP connectors have multiple size contacts (combinations of size 4, 8, 12, 16, 20) for this very reason.
