Posted 3/9/2025 14:13 (#11139868 - in reply to #11139708) Subject: RE: Slobbering sick calf
north central iowa
Always check a temp when you first treat it. It gives you a baseline and helps address going forward how to treat the calf. Make sure to check the ears to see if you have any drainage. You are using excellent antibiotics. An antihistamine injection may help the breathing. Hopefully you don't have much lung damage.
