coast of Maine | Mich veggy,Im in the camp of turbine broken off from shaft inside the H20 pump.With it only slipping 50 % it will pump and it will not pump enough.It will shock you when you see how dumb they are made.Im not 100% but 70% its your issue as you have been down the same tests as we were,,twice .Bearings will be looking fine and no leaks. | |
