Search Forums | Classifieds (101) | Skins | Language
Ball Bearing Parallel Arms vs bushings
ThePlowGuy
Posted 2/3/2025 15:35 (#11087357 - in reply to #11087341)
Subject: RE: Ball Bearing Parallel Arms vs bushings
So I have a customer that even after 1,100 + acres per row-unit running PP speed tubes with Delta Force in mostly no-till and no bearing fails that would equate to what in relation to bushings? Using a quality bearing and appropriately sized with the right type and amount of grease inside has prevented what you say will occur.
TPG
