Posted 12/1/2024 10:25 (#10990340 - in reply to #10990234) Subject: RE: 8850 Deere 4wd losing engine oil
east central ND
Yes, as nilbart says above, rear main leak normally turns hydraulic/transmission oil black. Other place to check for a leak is the valley under the injection pump, but that should be dripping on the ground with the volume of oil being added.
