Search Forums | Classifieds (77) | Skins | Language
Which lowboy to buy?
MaineFarmer
Posted 10/31/2024 12:39 (#10946090 - in reply to #10946067)
Subject: RE: Which lowboy to buy?
coast of Maine
Air ride,,way way simple.You can gain lowering ability as well.Hydraulic neck,off tractor if possible.The pony motor will get more salt/sand/dust/water than you can imagine ,,even in a box.BTDT.Non ground bearing is way easier as well.Kind of a misnomer as it lays on the ground but the ram stays on the truck and hook up remains on the neck.I can make it over a decent hump/track etc if I need by adjusting the neck ,2 ft high if needed.
