Dublin, VA | Running a cfx750 RTK with parani bt getting corrections from WVcors via Lefebure app. Works excellent for the most part, cmr age around 1sec. I will occasionally loose rtk fix. When it does cmr age will be 5-6sec and I will be down to 10-11 satellites (in a field with very few obstructions). I did add Beidou to constellation on display (glonass enabled as well) added a few more but didn't seem to help, WVcors says it supports gps/glonass/galileo/beidou. I'm about 30mi south from the closest base 45 to another to the east some. I suspect this may be some of the issue with being on the edge of the system. I'm considering my own base and ntrip caster but wanted to be sure it would actually help the issues. Not trying to have perfect 1" accuracy, have some good hills and just running ez-steer but when it works the accuracy and repeatability are great. Any thoughts?
(20240429_150111 (full).jpg)
Attachments ----------------
20240429_150111 (full).jpg (115KB - 63 downloads)
