| I posted about this a couple weeks ago. On our 870 the rear disc gang on the left side will drift downing it sits very long. It will also lose resistance overtime when working in the field letting that wing flesh more.When we store it in the shed till the next fall we have to chain it up. I asked if the cylinders were replacing or not but no one could tell me, including the service manager at our CIH dealership. Only thing he came up with is that the om says to run those had lines so that you pull back on the had lever to lower & push forward to raise, opposite of what we do. Tried that but didn't change anything in the field | |
