Search Forums | Classifieds (4) | Skins | Language
Belt baler
HuskerJ
Posted 11/20/2023 07:45 (#10489147 - in reply to #10489083)
Subject: RE: Belt baler
East of Broken Bow
Have a NH baler, and if hay is wet/sticky enough it will wrap like you described. Usually you can see the belts have uneven tension so you quit.
We used to have a fixed chamber baler, to this one, and our first lesson was that we had to let the hay get a little drier before we baled with the variable chamber baler, for two reasons.
One, it didn't like to bale green/wet/sticky hay nearly as well, and two, it would mold at a lower moisture than the fixed core bales.
