Search Forums | Classifieds (128) | Skins | Language
Dump truck hyd tank
   Forums List -> Where Can I find?????Message format
jdironman
Posted 11/19/2023 21:03 (#10488771)
Subject: Dump truck hyd tank
Nw Iowa
Have one of pyramid style hydraulic tanks on my old Mack that is leaking. This would be style that fits behind the cab and under the box. Used to be pretty common but can’t find a source for a new one. Mind is triangular shaped all the way to bottom and sits flat above frame rails, not in between them. I guess would prefer to find a nice one rather than weld up mine as it has cracked before.. thought about mounting a new one on frame but. Just not enough room with a mid mounted third axle. Thanks
