Search Forums | Classifieds (3) | Skins | Language
John Deere 608 stalkmaster loosing the cobs that are close to the ground
DBindiana
Posted 11/20/2023 06:07 (#10488996 - in reply to #10488664)
Subject: RE: John Deere 608 stalkmaster loosing the cobs that are close to the ground
West Central Indiana
Sounds like you have your corn head snouts adjusted down a lot. With them down even though the points might be touching the ground the entry point into the deck plates is sitting higher. If you adjust your snouts up some when you put the points on the ground the head itself is sitting lower and you can get more of those low ears.
