Search Forums | Classifieds (130) | Skins | Language
NAV900 to EZPilot Cable for EZPilot Pro or AMPD
Trimbleguy
Posted 11/13/2023 21:19 (#10481202 - in reply to #10477347)
Subject: RE: NAV900 to EZPilot Cable for EZPilot Pro or AMPD
SEQ, Australia
Yes, that 119793 cable will work, but you have to run switched power to the red and black wires in the Black DTM 12 that used to go into the IMD-600 as it is a link through to the SAM-200 Motor. There are 2 x Reds and 2 x blacks in the connector removed from the IMD-600 and you can join them together, but that keeps the SAM-200 powered all the time, hence the switched power is a better solution.
