Search Forums | Classifieds (47) | Skins | Language
Yield Monitor - JD 4240 display? (going from brown box)
BoilerFalcon
Posted 9/18/2023 09:18 (#10406107)
Subject: Yield Monitor - JD 4240 display? (going from brown box)
N Indiana
Is anybody using a John Deere Greenstar 4240 display to monitor and map corn & soybean yield? Does it work OK?
Wondering if we could use one as an upgrade. We currently run a brown box (2.5) yield monitor with side-mounted Greenstar moisture sensor on a 9510 combine.
What would we need to do to make a 4240 display monitor yield if the combine currently has all brown box wiring?
We'd also be interested in using it to monitor finger pickup planting, but yield monitoring is #1 concern.
