Central Illinois | We've got a hypro 9306c hyd drive pump on our fast sprayer. The hyd motor is leaking oil and needs to be fixed. So I'm trying to use the vast knowledge here so I may not have to do a lot of searching. We removed the hyd drives off of our CNH 1255 planter, would those motors work? If not is it better to put seals in the motor? Replace the motor? Buy a complete new pump? Any advice. Thanks
Edited by milkman1 6/1/2023 20:29
