Posted 6/1/2023 20:19 (#10252972 - in reply to #10252939) Subject: RE: Cyclo 800 problems - seed manifold
New Brunswick, Canada
No slip in the drivetrain for drum, cut all insecticide junk off. Stick a tiny bit of jumpy drive but no slip.
Had to change 4 or 5 bearings in the gearbox and 7/8” shaft.
Drum seal and wheel is ok.
Looking inside I see there is a brace rod on the manifold, there should be room for seed to get past the manifold if the release wheels aren’t rolling on drum?
