Posted 5/31/2023 20:07 (#10251416) Subject: Is it advisable
Va
Cat 320 excavator. Left boom cylinder is leaking from the seal. Has been for the last 25-30 hours. I’ve been told it’s a good idea to replace the seal in the other cylinder at the same time. Since the leak, the right side has been carrying more load. Fix the left and the right will be soon to follow. What say you? Pull em both?
