Southern Indiana | JD hay monitor gives code e2 01 as soon turn it on. Twine actuator disconnected is the code and to check wires and connectors. I spray conductor cleaner on all connectors and check wires for breaks made sure all pins pull up in connectors try to use the by pass switch will not make any difference has conductivity on the wiring. Any help would be greatly appreciated. Thank You
Edited by Dwc 5/31/2023 20:53
