SW MN Fulda | ronm - 5/30/2023 08:56
It's the fuel pump. I have this exact machine, & it's on its third fuel pump...started out like yours on the first one, got worse until I barely made it back to the trailer on the mountain.
The OEM pump is crazy expensive, the Chicom ones from ebay work OK...Pump is under the left front fender.
The only problem I have ever had with the carb is the o-ring that seals the float valve seat. Hardens up & lets fuel leak out the overflow when it's setting...
What pump do you recommend? Is there a way to check the current pump to see if that's the case? |
