Search Forums | Classifieds (187) | Skins | Language
Comparing Case IH tigermate to JD 2210 cult
LawrenceWelk
Posted 5/29/2023 21:16 (#10248773 - in reply to #10248731)
Subject: RE: Comparing Case IH tigermate to JD 2210 cult
Strasburg, ND
I've had a 60' Case Tigermate 200 since 2013. It's a 2011 or 12 model. Rougly 8,000 acres a year and furthest fields are 60 miles apart. I haven't had a bearing failure yet. Knock on wood.
Are the new bearings you put in junk? Are you installing/assembling them correctly? Are you overgreasing? Not being a dick, but if both models of diggers are having failures, what pratice are you doing to cause them to fail?
