Posted 5/29/2023 13:02 (#10248179 - in reply to #10247155) Subject: RE: Hydraulic cylinder, built in flow control?
SC WI
That is basically a pressure operated check valve. Keeps the bar from going down if you blow a hose. Measure the cylinders. I would think the 16/31 has bigger cylinders for the extra weight.
