Search Forums | Classifieds (192) | Skins | Language
Boxcar Magnum Hydraulic Outlets
plaptown
Posted 5/26/2023 11:31 (#10244421)
Subject: Boxcar Magnum Hydraulic Outlets
I know this has been discussed on here before, but couldn't seem to find the thread...
Anyways, we have a 7140 magnum with 4 hydraulic outlets. Ever since we've owned it, there's been issues with some outlets leaking (not around the hoses, but from relief valves on top/bottom etc). Sometimes using hydraulics in one outlet will cause oil to leak from a different outlet. Long story short, it seems we can usually get 2 of the 4 outlets to work when we need it.
Is this a common problem? Can you order seal kit? or better off replacing whole cartridge? or the whole assembly?
