Search Forums | Classifieds (76) | Skins | Language
Farmall h as a first tractor
jcfarmboy
Posted 5/26/2023 17:27 (#10244792 - in reply to #10244082)
Subject: RE: Farmall h as a first tractor
South Western Ontario, Canada
So I own Farmall H, M and 450D.
I make small bales too.....the M (with overrunning pto clutch adapter) can run the baler (NH570 with thrower) but only on maintenance or clean up. In the field it's not enough tractor.
The H is smaller and I honestly never put it on the baler....
The 450D is a ok size 45hp or so. Heavy hay or straw and you can't burn up the pto clutches in a hurry. This is my main all around tractor.
The H and M are wagon tractors as both are tricycle front ends.
When it's te to get stuff done the Allis 7060 comes out and work gets done.
You want to fit and pull an H please do.....but asking it to run a newer baler and you will be wasting so much time and fuel.
