Search Forums | Classifieds (66) | Skins | Language
1074 Rogator with JD Rate Controller
TJS
Posted 5/26/2023 05:38 (#10243958 - in reply to #10243590)
Subject: RE: 1074 Rogator with JD Rate Controller
Central Kansas
We added same setup to a 6103 terragator. Same problem. I'm convinced it is because the flow meter detects flow when it should be off. No idea how to fix it, needs some tolerance or like someone else said the 440 would quit detecting when shutboff. Try and shut your pump off when turning just to make sure that is your problem. Wouldn't be so bad if it didn't bring up that full warning screen and cover everything up.
