Search Forums | Classifieds (76) | Skins | Language
Working with boundaries
Pat H
Posted 5/22/2023 11:40 (#10239026)
Subject: Working with boundaries
I was using my markers on my forever old Kinze planter (16/31) for the end rows but then something failed and they stopped working. So I started to make AB lines for my end rows, etc. and I'm thinking of going further and using the field boundary file to use agleaders smartpath (yes I'm 10 years behind - I blame Leica). I use Becks Farmserver and it will output a field boundary file from my 20/20 planting data (rtk) that I assume I can import into a versa or integra. Does this work well? Just set up guidance with smart path and let it make AB lines? Is this what everybody does and I missed the meeting (again)?
I'm not super satisfied with some of my endrow passes so I may be recreating another boundary file after I plant next year. Am I better off setting up my side by side with a paradyme, versa and digifarm correction and create the boundary that way?
Thanks
