NE Indiana | For controlling, the Cruizer will only have the capability to turn the boom sections on/off. You would need to buy an Accuboom node and the kit for the SCS console. Your 450 would still do all of the actual controlling for the rate and the Cruizer would automatically turn the sections on/off in applied areas. If you are wanting to get rid of the 450 then you would need to go with the Envisio. You would need to buy a SwitchPro to go with it and it has an adapter cable to go to the 16 pin cable that is plugged into the 450. The Envisio would then control both the rate and also automatically turn the sections on/off. | |
